My revopoint mini has lost accuracy recently
I bought the Revopoint mini to do dental scans, recently non of the parts i make fit the new scans. When i do parts for my old scans they fit. I have calibrated and it didn’t help. Do any of you guys know what the problem is? My scans look good and the settings are the same.
Hi @cy2222
Sorry but I can’t evaluate the issue via the forum and see what is really going on , you will need to contact customer@revopoint3d.com for Technical assistance appointment, I recommend you to submit old and new project zipped for reference as well . This is only the way to find out what really changed.
The best result will be to scan new scan with the same old I next from preview old scan.
Accuracy is build into the scanner , it can’t change on itself , you can try to scan with the same older software you scanned before or update to the newest if you did not do it already .
That’s all I can help you here out .
