Move scans to different project
Hi,
I start a project on my Miraco and then transfer the files to my desktop. I process the files and realize I need one more scan to fill in some details.
I go back to the miraco, locate the project, and then add the new scan to that same project. when I the import the project again to get that new scan it puts it in a new project folder with the same name but appended with a (1). how do i add that new scan to the main project file I had been fine tuning on the computer?
Thanks!
Hi @MattBro
Remove the old project you downloaded before uploading the new updated one with the additional scan .
ok so any refining I did to the original project is lost and has to be redone?
You can’t update a project that you already edited with a project that was never edited .
if that was possible the old project would be overwritten and that’s what you don’t want.
If you want to merge the second scan with the first one , just fuse it , clean it, export as ply and import to the old project and save.
