Miraco textures are bugged
I’ve been using the Miraco to scan textured models but lately all the textures i’ve tried to capture are severely bugged. All of these scans have been done with studio lighting by a professional, and should be very clean. However this is all i’m getting…
Hi @Herr_Jordel
Can I see the lighting setup because from that example it looks like it is not the proper lighting setting.
I am doing commercial photography for decades as well
So if you show me your setup I can give you the right point to capture it better .
Hello, could you please provide us with the projecct files of this model? We will have the R&D team analyze it to see what happened .
Thank you! We found the issue!
Apparently our scanner needed an update. After the update everything is fixed
That what I suggested yesterday to our team after closely investigating your image and the discoloration .
Glad to hear you find it out because I was for plan to suggest you the firmware checking / update
Remember to use the latest RevoScan 5.5.2 together with MIRACO
Thanks for letting us know
