MIRACO Series Products V1.2.1 Software Update Notice
To update, connect MIRACO to Wi-Fi and go to Settings. The Software Update option will have a red dot notification next to it. Tap on it to download the update, and then wait for the installation process to complete.
App Version: V1.2.1.31 System Version: V2.6.38.20241025
Updates:
  1. Improves photogrammetric function experience. (MIRACO Plus only)
  2. Adds Global Marker Tracking mode
    New “Global Marker” and “Based on the Global Marker” scanning functions: First, capture a global marker framework of the area, then perform point cloud scanning based on them. This method is particularly effective for medium to large objects, improving scanning efficiency, frame stitching, and reconstruction accuracy.
  1. Changes some interface and UI copy.
  2. Adds Turkish language support.
  1. Adds a digital zoom function with 1.5x and 2x zoom.
    Adds 1.5x/2x digital zoom to the depth camera: Zooming in on the scanning screen helps users focus on the main content and crop out the background, enhancing the scanning experience.
  1. Fixes some bugs.
  2. Adds model post-processing hole filling method.
    Enhances the Manual Hole-filling function: Adds Plane/Curved Hole-filling method and optimizes hole selection.
Thanks, updated successfully for me - will test soon
hello Team
update stuck at 99% , tried several network, any solution?
Hi @promill
We recommend you reboot MIRACO, go into the settings, recheck for updates, and download it. If you encounter any further issues, please contact us again. We will work on improving this situation in the future. Thank you for your understanding.
Great update
In Turkish language on new software Shutdown and Restart buttons reversed.
Calibration with Revoscan 5.5 won’t work
After the new firmware update ?
I updated but, no time yet to re calibrate . Tony said everything went smooth .
So what is happening ? Board don’t get recognized or what ?
Yes after the new firmware update: Miraco calibration problem - #45 by SphaeroX
Ok I saw the video but see no issue … did it saved the calibration or not ?
Because if not then the problem is with any other scanner and not just MIRACO … software bug
The software tells me I have to calibrate, when I calibrate then the error comes at the end (see video).
Hi Şuayb, thanks for bringing this up, we’ll change it.
Hi @SphaeroX, we’ll check this out for you soon.
Default project name has changed to Project{year/month/date}_{time}. I thought my day’s worth of scans had disappeared since they were at the top of the list instead of the bottom. :slight_smile:
I was sort of in this position, at 99%, so I touched the screen, and it finished the update.
It may not work for you, and it may just be a coincidence.
