Hi,
CONTEXT:
- Ive had the Miraco 2 days, Ive had the Artec 13 years. So my knowledge needs help for the Miraco…
- I mainly scan aircraft. I do the landing gear, wheel well/cavity, cockpit/controls, bathroom, a seat, engine guts, luggage compartment, interior detailing. And any other parts that are complicated to model without scan reference.
- a cockpit is the heaviest, usually about 10000 frames with the Artec.
1 - why is the software so slow for post-production? Running on the same fast PC, Artec Studio 18 is very fast to load scan frame sequences and manipulate data. Factor of 10x over RevoScan 5 maybe? Software seems to run at the same speed on the unit as it does on the PC, which is strange. Any plans to multi-thread?
2 - Can I cut frames from a scan sequence to be a ‘new’ scan? This is invaluable when trying to fine-tune scan registration (line up frames). If the scanner loses registration during scanning, there seems to be no way to move the frames in post. Only delete them? So if it loses registration during scanning, should I start again?
3 - is the scanner extremely sensitive to high contrast lighting scenarios? I tested in and around my car, which was in the shade, but it was a bright day. And also at home in the night time. The car was a disaster, at home it scanned well. Is low light much better?
4 - can I ‘cheat’ adjustments in windows folders…ie: copy folders, delete frames, rename folders etc?
5 - when using ‘Auto’ for exposure… does it dynamically change exposure? Or does it set it at the beginning of the scan and that value remains in place until the end of the scan?
6 - Registration issues - how do you rectify registration issues in post? Ive not yet done a scan where Im not seeing offset frames. In Artec Studio i can isolate these individually or as small sequences, then cut/paste to a new scan. Then, as I have both scans (extracted from the same original sequence) I can align them using the Align feature (semi-manual or auto).
Honestly, I appreciate the simplicity of the toolset, but the scanner is not robust enough in its tracking to allow for such simplicity. I just cant get good scans of my chosen subject matter. Mainly due to inflexibility in fixing registration issues. Any help MUCH appreciated.
