This scan was done in parallel line mode. I didn’t mount the part on purpose. First, I scanned on a turntable in Full Field and Parallel Laser mode. But the geometry here is too complicated for a turntable, you need a lot of circles at different angles to look into all the elements. After that, I scanned this part in manual Parallel Laser mode, spending about 20 minutes on it, made two scans, they perfectly matched. Then there was the reverse and the render. At the request of the customer, I did not round it off and simplified the details in some places, because the customer wants to refine it himself in Solid Works.
Hi Michael,
what’s your reverse engineering software?
Thomas
Great scan and reverse engineering here ! Well done !
Thanks!!! ![]()
Hi! I use togeyher Siemens NX + Geomagic Design X. Render in the Keyshot
