Metro Y Pro & Trackit - Revo Metro blocks performance test ("Specs too low") & persistent warnings despite high-end setup (Ryzen 9 9900X3D / RTX 4070 / 64GB DDR5)
Hi Revopoint team and community,
I own and use both the Metro Y Pro and the Revopoint Trackit.
Every time I start Revo Metro, the software displays an error/warning stating that my CPU lacks enough cores / is too weak, and that I have less than 64 GB of RAM. Worse yet: Revo Metro completely forbids and blocks me from running the performance benchmark, claiming my system configuration is too low to even run the test.
I have tried toggling between GPU mode and CPU mode in the software settings, but the issue persists identically in both modes: the warning remains and the benchmark stays locked out.
I recently upgraded my entire system specifically to handle heavy tracking and high-density point clouds:
Old setup (which ran without this warning):
  • CPU: AMD Ryzen (AM4 platform)
  • GPU: ASUS ROG Poseidon GTX 1080 Ti (11 GB GDDR5X)
  • RAM: 128 GB DDR4
Current upgraded setup:
  • CPU: AMD Ryzen 9 9900X3D (12 Cores / 24 Threads confirmed active in Windows and CPU-Z)
  • Motherboard: Gigabyte B650 EAGLE (BIOS updated, “X3D Turbo Mode” disabled, SMT enabled)
  • RAM: 64 GB DDR5-6000 MHz (EXPO 1 enabled, running dual-channel at 5994 MT/s)
  • GPU: Gigabyte NVIDIA GeForce RTX 4070 (12 GB GDDR6X, PCIe 4.0 x16)
  • Storage / Paging: PCIe 4.0 NVMe SSDs (Seagate FireCuda 530 up to 7300 MB/s + Samsung 980 1TB) with a 32–64 GB virtual memory pagefile configured
  • Software: Revo Metro (latest version)
Checks already performed:
  1. Initially, the motherboard’s default “X3D Turbo Mode” had disabled 6 cores and SMT. That has been completely resolved: CPU-Z and Task Manager now properly report all 12 physical cores and 24 logical processors, with full L3 cache access (96 MB + 32 MB).
  2. The dedicated RTX 4070 is set as primary for high performance in Windows.
  3. Virtual memory (pagefile) was expanded on the NVMe drive.
  4. Tested both GPU and CPU processing modes with no change in software behavior.
The software seems trapped in an initial failed check, flags top-tier hardware as under-spec, and refuses to run the benchmark to re-evaluate the system.
Questions:
  1. Where does Revo Metro store its cached hardware/benchmark profile, and how can I delete or reset it manually?
  2. Why is the performance test button disabled when detecting 64 GB physical RAM, and how can this lockout be bypassed?
Thank you for your support and feedback!
Hi @Zoltan3D
I recommend you write an email to customer@revopoint3d.com
I can even run the check on my Windows 11 i7 8th Gen tablet with 16GB of RAM.
There must be something that prevent the software to access the actual specs, I am sure the technician will help you out.
