Hello, I’m trying to merge two view of the same object.
I would like join two view using the markers, I had place before.
But the markers are no longer visible.
I’ve find a video with Shining that merge two scans using markers.
I would like make the same process with
3d scan on its side.
Then use manual mode and place some point in the same area on both scans.
There are no specific features to use.
You can still see the markers placed on the edges. Use those as your points
I agree, but is a little triky, it would be better to see the markers in clear
Yes that would be nice to allow marker alignment.
But the software as of now does not. So in this case you use would use manuak alignemnt. Pick 3 or more points in common.
Thankyou Xile6, I hope this will be implemented in the future (Revopoint please…)
Hi @Fabio65
There was a very good workflow that I developed in early versions but sadly right now it is not available as the software is still WIP.
Who knows what the future brings !
We trust in the future,
Happy Easter
Happy Easter @Fabio65
On Tuesday April 7, there will be a new update for Revo Metro, check it out after release.
@PUTV Thinking to help me, I’ve try to merge models, scan before in RGB mode, but when models are selected for merging, they are display in one colour, non in RGB
Hi @Fabio65
The update is shifted to the middle /end of this week due to some bugs that need to be addressed.
Regarding RGB preview under Merge tab it is not available and I miss it as well .
