Ok So I get myself a pop scanner and really not getting the quality, My fault in ordering it and not getting the Mini, So the Mini is on the way to me and after lots of reading and videos I know that is the scanner for me and my work.
After a lot of reading I know the min size scan is 10x10x10mm but have not seen too much about the MAX size or is it as big as you want and subject to your computer doing all the work?
Just what I thought and thank you for the reply, Cant wait to get my Mini now and start the massive learning curve of scanning and know it will take time to learn
MINI was made for scanning very small objects since the FOV is very small , the reason it is called MINI , scanning big objects will cost you a lot of work , since you have to be very close up to get the fine details , scanning objects with a lot of features or use a lot of markers .
I think POP2 is most ideal for small and big objects … I would use MINI only for very small objects and not bigger than 13 cm at max .
Can you scan big? well with a 13 inches/30cm object you will have already lots of data to deal with and long processing time … so huge objects will be a monsters to be processed .
