I scanned a water hydrant in my neighborhood with my Miraco.
My workflow was to scan in Far mode, starting and pausing the same scan, until I had (I thought) everything. After fusing the point cloud in the Miraco, I noticed that the raised text was not as clearly defined as I would have liked, so I resumed the scan, switched to Near mode and continued for a few frames.
Tracking was acquired quickly, so I was not expecting what I found when I moved the project to my computer.
As can be seen in the Fuse NoRGB image, the bas-relief text was duplicated below and slightly to the left of the actual text as an outline (not bas-relief).
With the color display activated, Fuse RGB shows that the duplicate text is still present, but more closely bas-relief than in the colorless fused image.
In the Mesh NoRGB image, the duplicate text disappears, but is still present in the Mesh RGB image.
Texture mode finally displays both color and no-color properly.
