I need to merge two meshes from two separate projects.
I open one of the two projects and import the mesh from the second project.
When I select the command to merge the meshes, the imported mesh is disabled and does not allow me to select it, therefore, I cannot merge them.
What am I doing wrong?
You need to export a point cloud from project A and import it in project B, not the mesh.
PERFECT! It’s work!
tnks! ![]()
