How to read the depth camera
Hi there!
I’ve been trying to read the POP2 depth camera directly as one would a webcam.
Simple OpenCV capture from the device yields a two by two green / pink image, obviously composite of the two perspective cameras.
At first I hoped the color meant distance, however comparing with 3DViewer, the POP2 is generating data for a good depth map of the test head, where all three channels of the direct capture image are completely saturated, with absolutely zero data e.g. around the eye area.
What am I doing wrong, do I need a particular library or driver to read from the depth camera? Am I using some stupid image format? Any direction much appreciated!
For technical hardware questions please contact customer@revopoint3d.com
Have a nice day
Awesome thanks! Did something happen to the thread? We had more posts here with specifics about what I was asking
After you flagged my reply the system removes all replies linked to the post.
The other thread in interest is where you posted your question is originally under Developer section.
Ah ok, I don’t know my way around the forums very well clearly! I reached out to revopoint by email like you suggested and they’ve been really helpful, just looping in an expert to tell me about the depth format
That’s good to hear.
Maybe @X3msnake can help you out with this info, because he was into it for a while.
Got my setup sorted while we wait to hear back. Have made progress accessing sensors but struggling to set gain and exposure without calling via SDK
I’ve got a reliable little prototype python script for reading the camera streams.
So far I’ve totally failed to set device parameters outside of revopoint software, and that means I’m receiving pair 8 bit IR on the depth stream (ignore any comments in the code that indicate otherwise). The key next step is setting the stream type, the depth conversion is done on the device, while the point could projection is done by the 3DCamera library. That means without accessing the depth stream my whole project is a non starter!
#!/usr/bin/env python3
"""Rought script to capture IR and color images from a Revopoint 3D camera"""
import cv2
import numpy as np
import os
import time
import sys
import wmi
import csv
def get_revopoint_cameras():
    """Get Revopoint RGB and Depth cameras using WMI."""
    revopoint_cameras = []
    try:
        c = wmi.WMI()
        wmi_devices = c.Win32_PnPEntity()
        for device in wmi_devices:
            if hasattr(device, 'Caption') and device.Caption is not None:
                # Look specifically for Revopoint cameras
                if device.Caption.startswith("RGBCam") or device.Caption.startswith("DepthCam"):
                    dev_info = {
                        'name': device.Caption,
                        'hardware_id': device.PNPDeviceID if hasattr(device, 'PNPDeviceID') else None,
                        'is_depth': device.Caption.startswith("DepthCam")
                    revopoint_cameras.append(dev_info)
                    print(f"Found Revopoint camera: {device.Caption}, hardware ID: {dev_info['hardware_id']}")
        return revopoint_cameras
    except Exception as e:
        print(f"Error detecting Revopoint cameras: {str(e)}")
        return []
def extract_device_id_from_hardware_id(hardware_id):
    """Extract the device ID part from the hardware ID string."""
    if not hardware_id:
        return None
    # The hardware ID format typically contains VID (Vendor ID) and PID (Product ID)
    parts = hardware_id.split('\\')
    if len(parts) >= 2:
        # Extract the VID_PID part and the unique instance ID
        vid_pid_part = parts[1].split('&')
        if len(vid_pid_part) >= 2:
            vid_pid = f"{vid_pid_part[0]}_{vid_pid_part[1]}"
            # If we have an instance ID, include that for uniqueness
            if len(parts) >= 3:
                return f"{vid_pid}_{parts[2]}"
            return vid_pid
    return hardware_id  # Return original if parsing fails
def check_opencv_camera(index):
    """Check if camera at given OpenCV index is available and get its properties."""
    camera_info = {
        'index': index,
        'available': False,
        'resolution': None
    cap = cv2.VideoCapture(index)
    if cap.isOpened():
        camera_info['available'] = True
        # Get resolution
        width = int(cap.get(cv2.CAP_PROP_FRAME_WIDTH))
        height = int(cap.get(cv2.CAP_PROP_FRAME_HEIGHT))
        camera_info['resolution'] = f"{width}x{height}"
        # Release the camera
        cap.release()
    return camera_info
def map_revopoint_cameras(max_cameras=10):
    """Map Revopoint cameras to OpenCV indices using hardware IDs and position."""
    # Get Revopoint cameras from WMI
    revopoint_cameras = get_revopoint_cameras()
    # Extract device IDs for WMI cameras for easier matching
    for cam in revopoint_cameras:
        cam['device_id_part'] = extract_device_id_from_hardware_id(cam['hardware_id'])
    # Suppress OpenCV error outputs
    previous_log_level = cv2.getLogLevel()
    cv2.setLogLevel(0)
    # Check available OpenCV cameras without verbose output
    opencv_cameras = []
    for i in range(max_cameras):
        camera_info = check_opencv_camera(i)
        if camera_info['available']:
            opencv_cameras.append({
                'index': i,
                'resolution': camera_info['resolution']
            print(f"Found OpenCV camera at index {i} - Resolution: {camera_info['resolution']}")
    print(f"Found {len(opencv_cameras)} available OpenCV camera(s)")
    # Restore previous log level
    cv2.setLogLevel(previous_log_level)
    # Find RGB and Depth cameras in the WMI list
    rgb_camera = next((cam for cam in revopoint_cameras if not cam['is_depth']), None)
    depth_camera = next((cam for cam in revopoint_cameras if cam['is_depth']), None)
    # Positional mapping: Assumes index 0 is Depth, index 1 is RGB
    camera_mapping = {}
    if len(opencv_cameras) >= 1 and depth_camera:
        camera_mapping[opencv_cameras[0]['index']] = {
            'opencv_index': opencv_cameras[0]['index'],
            'name': depth_camera['name'],
            'hardware_id': depth_camera['hardware_id'],
            'resolution': opencv_cameras[0]['resolution'],
            'type': 'Depth',
            'match_method': 'Position-based (index 0)'
    if len(opencv_cameras) >= 2 and rgb_camera:
        camera_mapping[opencv_cameras[1]['index']] = {
            'opencv_index': opencv_cameras[1]['index'],
            'name': rgb_camera['name'],
            'hardware_id': rgb_camera['hardware_id'],
            'resolution': opencv_cameras[1]['resolution'],
            'type': 'RGB',
            'match_method': 'Position-based (index 1)'
    # Print final mapping
    print("Using position-based mapping (index 0 = Depth, index 1 = RGB)")
    for idx, info in camera_mapping.items():
        print(f"OpenCV Index {idx} -> {info['name'] if 'name' in info else 'Unknown'} ({info['type']})")
    return camera_mapping
def list_cameras(max_cameras=10):
    """List all available cameras with their properties."""
    # Suppress OpenCV error outputs temporarily
    cv2.setLogLevel(0)
    print(f"Scanning for cameras (checking indices 0-{max_cameras-1})...")
    # First try to map Revopoint cameras
    camera_map = map_revopoint_cameras(max_cameras=max_cameras)
    # Now check for any other cameras not in the mapping
        if i not in camera_map:
            cap = cv2.VideoCapture(i)
            if cap.isOpened():
                # Get camera info
                fps = cap.get(cv2.CAP_PROP_FPS)
                # Try to read a frame to confirm it's working
                ret, frame = cap.read()
                status = "OK" if ret else "No Frame"
                print(f"Camera {i}: {width}x{height} @ {fps:.1f}fps - Status: {status}")
                # Check if this could be a depth camera (typically single-channel)
                is_depth = False
                if ret and frame is not None:
                    if len(frame.shape) == 2 or (len(frame.shape) == 3 and frame.shape[2] == 1):
                        print(f"  Likely a depth camera (single channel)")
                        is_depth = True
                # Add to the mapping
                camera_map[i] = {
                    'opencv_index': i,
                    'resolution': f"{width}x{height}",
                    'fps': fps,
                    'type': 'Depth' if is_depth else 'RGB/Color',
                    'status': status
                cap.release()
    # Restore log level
    # Get camera indices - simplified to use position-based mapping
    depth_idx = 0  # Position-based: depth camera is index 0
    rgb_idx = 1    # Position-based: RGB camera is index 1
    return depth_idx, rgb_idx, camera_map
def print_camera_properties(cap, camera_name):
    """Print all available properties of a camera."""
    title_string = f"=== {camera_name} Camera Properties ==="
    print(title_string + ("=" * (40 - len(title_string))))
    # Common properties to check
    properties = {
        cv2.CAP_PROP_FRAME_WIDTH: "FRAME_WIDTH",
        cv2.CAP_PROP_FRAME_HEIGHT: "FRAME_HEIGHT",
        cv2.CAP_PROP_FPS: "FPS",
        cv2.CAP_PROP_FOURCC: "FOURCC",
        cv2.CAP_PROP_FORMAT: "FORMAT",
        cv2.CAP_PROP_CONVERT_RGB: "CONVERT_RGB",
        cv2.CAP_PROP_BRIGHTNESS: "BRIGHTNESS",
        cv2.CAP_PROP_CONTRAST: "CONTRAST",
        cv2.CAP_PROP_GAIN: "GAIN",
        cv2.CAP_PROP_EXPOSURE: "EXPOSURE",
    for prop_id, prop_name in properties.items():
        try:
            value = cap.get(prop_id)
            # Special handling for FOURCC to convert to readable format
            if prop_id == cv2.CAP_PROP_FOURCC:
                fourcc_int = int(value)
                fourcc_chars = chr(fourcc_int & 0xFF) + chr((fourcc_int >> 8) & 0xFF) + chr((fourcc_int >> 16) & 0xFF) + chr((fourcc_int >> 24) & 0xFF)
                print(f"{prop_name}: {value} ({fourcc_chars})")
            else:
                print(f"{prop_name}: {value}")
            print(f"{prop_name}: Error - {str(e)}")
    print("=" * 40)
def extract_depth_data(buffer, width, height):
    Extract 16-bit depth data from camera buffer.
    Args:
        buffer: Raw data buffer or frame
        width: Width of the depth image
        height: Height of the depth image
    Returns:
        16-bit depth image as numpy array
    try:
        # For 2D array input
        if isinstance(buffer, np.ndarray):
            if len(buffer.shape) == 2:
                # Already a 2D array, convert to 16-bit
                print("Converting 2D array to 16-bit")
                if buffer.shape[0] == 1:
                    # Reshape flat array to 2D
                    buffer_reshaped = buffer.reshape(height, width)
                    depth_array = buffer_reshaped.astype(np.uint16) * 256
                else:
                    depth_array = buffer.astype(np.uint16) * 256
            else:
                # Convert other array formats
                depth_array = np.array(buffer, dtype=np.uint16)
        else:
            # Create a placeholder for incompatible input
            print("ERROR: Could not interpret buffer as depth data")
            depth_array = np.zeros((height, width), dtype=np.uint16)
        return depth_array
        print(f"Error extracting depth data: {str(e)}")
        # Return empty array on error
        return np.zeros((height, width), dtype=np.uint16)
def save_depth_frame_as_csv(frame, output_dir, timestamp):
    Save the depth frame as left and right CSV files.
    Args:
        frame: The depth frame data
        output_dir: Directory to save the output
        timestamp: Timestamp for the filename
    Returns:
        List of paths to the saved CSV files
    try:
        print(f"Frame shape: {frame.shape}")
        saved_files = []
        # Ensure the frame is properly shaped
        if len(frame.shape) == 1 or (len(frame.shape) == 2 and frame.shape[0] == 1):
            # This is a flat array that contains both left and right images
            flat_frame = frame.flatten()
            total_pixels = flat_frame.size
            # Split the frame into two equal parts (left and right)
            half_size = total_pixels // 2
            # Extract left and right data
            left_data = flat_frame[:half_size]
            right_data = flat_frame[half_size:2*half_size]
            # Reshape each half to 2D
            h, w = 400, 640  # Default dimensions
            # Check if we have enough data for both images
            if half_size >= h * w:
                left_frame = left_data[:h * w].reshape(h, w)
                right_frame = right_data[:h * w].reshape(h, w)
                # Save left frame
                left_csv_filename = os.path.join(output_dir, f"depth_left_{timestamp}.csv")
                with open(left_csv_filename, 'w', newline='') as csvfile:
                    writer = csv.writer(csvfile)
                    for row in left_frame:
                        writer.writerow(row)
                print(f"Saved left depth data to: {left_csv_filename}")
                saved_files.append(left_csv_filename)
                # Save right frame
                right_csv_filename = os.path.join(output_dir, f"depth_right_{timestamp}.csv")
                with open(right_csv_filename, 'w', newline='') as csvfile:
                    for row in right_frame:
                print(f"Saved right depth data to: {right_csv_filename}")
                saved_files.append(right_csv_filename)
            else:
                print(f"Warning: Not enough data to create two {w}x{h} images (have {total_pixels} pixels, need {2*w*h})")
                # Save original frame as a fallback
                csv_filename = os.path.join(output_dir, f"depth_full_{timestamp}.csv")
                with open(csv_filename, 'w', newline='') as csvfile:
                    # Reshape to 2D if possible
                    if total_pixels >= w * h:
                        reshaped = flat_frame[:w * h].reshape(h, w)
                        for row in reshaped:
                    else:
                        # Just write as a single row
                        writer.writerow(flat_frame)
                print(f"Saved full depth data to: {csv_filename}")
                saved_files.append(csv_filename)
        else:
            # For already 2D frame, save as is (fallback)
                for row in frame:
        return saved_files
        print(f"Error saving depth as CSV: {str(e)}")
        return None
def capture_frames(output_dir="./captured_data"):
    Capture RGB and depth frames from the detected cameras.
    Args:
        output_dir: Directory to save the captured data
    # Create output directory if it doesn't exist
    if not os.path.exists(output_dir):
        os.makedirs(output_dir)
    timestamp = time.strftime("%Y%m%d_%H%M%S")
    # Auto-detect cameras
    depth_idx, rgb_idx, _ = list_cameras(max_cameras=10)
    # Default dimensions for depth frame
    width, height = 640, 400
    prev_log_level = cv2.getLogLevel()
    cv2.setLogLevel(0)
    # 1. Open Depth camera setting CONVERT_RGB=False
    depth_cap = cv2.VideoCapture(depth_idx)
    depth_cap.set(cv2.CAP_PROP_CONVERT_RGB, 0)
    if not depth_cap.isOpened():
        print(f"Error: Could not open Depth camera {depth_idx}")
        return False
    print_camera_properties(depth_cap, "Depth")
    # Get actual dimensions from camera
    width = int(depth_cap.get(cv2.CAP_PROP_FRAME_WIDTH))
    height = int(depth_cap.get(cv2.CAP_PROP_FRAME_HEIGHT))
    # 2. Open RGB camera if available
    rgb_cap = None
    if rgb_idx is not None:
        rgb_cap = cv2.VideoCapture(rgb_idx)
        if not rgb_cap.isOpened():
            print(f"Warning: Could not open RGB camera {rgb_idx}")
            rgb_cap = None
        else:
            print_camera_properties(rgb_cap, "RGB")
    # 3. Capture Depth frame
    ret, depth_frame = depth_cap.read()
    print(f"Depth frame capture result: {ret}")
    if not ret or depth_frame is None:
        print("Error: Failed to capture Depth frame")
        depth_cap.release()
        if rgb_cap:
            rgb_cap.release()
        return False
    # Determine frame dimensions
    if len(depth_frame.shape) == 3:
        frame_height, frame_width = depth_frame.shape[:2]
    elif len(depth_frame.shape) == 2:
    else:
        frame_height, frame_width = height, width
    # Extract 16-bit depth data
    depth_16bit = extract_depth_data(depth_frame, frame_width, frame_height)
    # 4. Capture RGB frame if available
    if rgb_cap:
        ret, rgb_frame = rgb_cap.read()
        print(f"RGB frame capture result: {ret}")
        if not ret or rgb_frame is None:
            print("Warning: Failed to capture RGB frame")
        else:
            # Save RGB frame
            rgb_filename = os.path.join(output_dir, f"rgb_{timestamp}.png")
            cv2.imwrite(rgb_filename, rgb_frame)
            print(f"RGB frame saved to: {rgb_filename}")
    # 5. Clean up
    depth_cap.release()
    if rgb_cap:
        rgb_cap.release()
    # Restore log level
    cv2.setLogLevel(prev_log_level)
    # Save depth data as CSV
    csv_file = save_depth_frame_as_csv(depth_16bit, output_dir, timestamp)
    return csv_file is not None
if __name__ == "__main__":
    if capture_frames(output_dir='./captured_data'):
        print("Capture and processing completed successfully.")
    else:
        print("Capture or processing had errors.")
        sys.exit(1)
