After getting the firmware updated and the dual axis turntable setup, i was excited to be able to start scanning. it scanned the included bust without issues. However, when I tried to scan this grogu statue (6" tall), I had to back the scanner 12" away just to be able to get the whole body, and the scan came out with gibberish.
Your maximum distance should be 20cm from the object to your scanner not 12 inches .
MINI operates best between 10-20cm distance, to scan bigger objects that do not fit in your depth cam preview check my video .
I used POP2 here but that don’t matter, the workflow is the same .
Scan from top to the bottom slowly moving down each section each 360 degrees rotation .
