Hello, in the tracking mode: feature tracking, it is possible to select a dark object. Could you please make it so that in Global Marker Tracking, it would also be possible to select a dark object? Thank you.
Global Marker mode only scans markers , after that you reuse the markers cloud and scan your actual object . Use the Auto Exposure and most dark objects will be scanned .
BUT not all as that depends of the objects material , this exclude black plastic , rubber, acrylic or any surfaces painted with oil or acrylic black paint since it absorbing infrared . Please remember that very dark objects can affect the accuracy , use proper 3D spray to prepare the surface of accuracy is important to you .
I understand what you mean, but I still get better results with the same object with the dark setting
same object, same powder treatment, same angle, only different settings in that dark
and that figure is not black, it is colored and powder is applied to it
Do you know if it could be modified?
