Filling in bigger holes
How do you go about filling in bigger holes
Hi @Muzza
How big of a hole do you want to fill? Can you take a photo to show us?
Bigger holes should not be closed , the function is only for makr the scan water tight , closing bigger holes will not replace the missing part, you need to scan an object with a 3 different angles for perfect 3D scan and merge them together .
So if you have big holes , scan another angle and capture the missing areas them merge them together .
