I’ve been using a Miraco a lot, and it has reignited a couple ideas I had when using the mobile application:
Import into an existing project
- Currently when you import from Miraco or the mobile application, it automatically creates a new project.
- I would suggest giving a user dialog with two option: Import into currently active project or into a new project.
Import Button on Homescreen
- UI Goals typically involve as few clicks as possible for the end-user to perform a specific option.
- Currently to Import you have to either open or start a new project, and then after Import is complete it takes you to the project you just imported.
- This is because the Import function can only be accessed from the “File” menu drop-down dialog that is only available while in a project. As a result, an unnecessary step is required to perform an Import.
- Having the “File” dropdown dialog available on the homescreen or having an “Import” button on the homescreen would be a simplification of the process that many end-users perform frequently.
Just a couple ideas - I’m open to any discussion or feedback anyone has!
