Dfodaro - Beta Showcase MIRACO 3D Scanner - ART - SCULPTURE - CULTURAL HERITAGE
MIRACO SCANNING “SAFARI” - around downtown Rome
Baroque age - painted and gilded stucco - bas-relief - Angel - San Bartolomeo all’isola Tiberina basilica
Follow the MIRACO project on Kickstarter: Revopoint MIRACO: Big and Small Object Standalone 3D Scanning
Author: Roman workshop
Type : Sculpture
Age: Baroque age
Material and technique: Stucco, modelled, painted, gilded
Size: 100 high x 75 cm wide
Single Module device, far mode, continuos, standard accuracy
Light condition: Artificial
The scan was edited and processed on pc
Raw
Fusion
Screenshot 2023-10-20 084653
Cleaning before meshing
Meshing
Screenshot 2023-10-20 084511
Meshed
MeshLab
MeshMixer
Medioeval age - carved marble - stilophore lion - Santi Apostoli basilica
Type : Sculpture
Age: 1190 ca
Material and technique: Carved and polished marble
Size: 120 high (with pedestal) x 75 cm wide
Single Module device, near mode, continuos, standard accuracy
Light condition: Natural
Raw
Fusion
Screenshot 2023-10-20 092150
Fused
Meshing
Screenshot 2023-10-20 100230
Meshed
MeshLab
MeshMixer
Pre order MIRACO now on Revopoint official website: Revopoint MIRACO: Big and Small Object Standalone 3D Scanning
great showcases and amazing sculptures. Thank you for sharing!
What is your opinion on Miraco vs Range, as you use both for such objects?
Hi Ivan,
Thanks for your appreciation
Miraco has a new design and allows us to use it totally free: no computer, no smartphone, no cables, no powerbank. It is a lightweight design, compact and unobtrusive, and allows you to take it anywhere ( I use it really comfortable and easy on a scaffold). The ability to use it in continuos or single shot mode (in an integrated and complementary way as well) is really amazing. Also you can use it in both far and near mode.
It also allows you to use it without the need of a pc (all operations can be done directly with Miraco: scanning, fusing, editing and meshing- made the test and it works -watch my video).
This is my opinion
thx for replying. so would you prefer using it anytime over Range for such bigger objects?
Absolutely
MIRACO SCANNING Small Dark Bronze Sculpture
Sleeping Nymph
Author: (after) Jean-Baptiste Carpeaux (Valenciennes 1827 – Courbevoie 1875)
Type: Sculpture
Age: early XX century
Material and technique: patinated Bronze, black marble, casting, carving
Size: 20 x 15 x 9 cm ca (including the marble base)
Single Module device, near mode, single shot, high accuracy
In this post, I tested MIRACO’s ability to scan a very dark surface.
Is a small bronze sculpture with dark patina, mounted on a molded base of black veined marble.
All of the scanning and follow-up stages were recorded with MIRACO’s screen shot function.
I conducted two scanning tests: the first without any kind of surface treatment, the second test was done by treating the surface with Attblime spray (a specific scanning product that does not negatively interact with, nor damage in any way, the materials to which it is applied, and sublimates after a few hours).
First test: no treatment
MeshLab
As you can see the scan of the dark bronze surface was acquired by MIRACO without any particular problems.
Instead, the polished black marble base was partially scanned.
Second test: Attblime spray treatment
With the spray-treated surface, the glossy black marble base was also scanned.
Meshmixer
:warning: BETA DISCLAIMER: :warning:
These showcases were made with an early beta version of MIRACO
MIRACO SCANNING OUTDOOR BIG Stone Fountain Mask
Travertine fountain mask - Giuseppe Gioacchino Belli Monument
Autore: Michele Tripisciano (1860-1913 )
Dating: 1913
Materials: Travertine, Marble
Single Module device, far mode, continuos mode, standard accuracy
One of MIRACO’s most important features is undoubtedly the to simply carry-on, thanks to its size and weight (only 750 g), as if it were a camera.
Let’s see how it behaves in an outdoor scanning situation.
For this test I chose a monument with a fountain; the scan was taken at 8 a.m. on a cloudy day.
Below are pictures monument, the different fases and the result della scansione. There is also a video of scanning (made with screen recording option by MIRACO) and other one with “frame by frame” scanning animation.
Size
RAW
FUSED
MESHED
MESH+COLOR
TEXTURED
MESHLAB
The upper part was not reachable (for the pool with water in front of the fountain)
Scan done in the morning at 8 am and edited later on pc
VIDEO - scanning
VIDEO - frame by frame scanning animation
Your showcases never fail to impress. Some of the objects you scan are extremely challenging.
Thanks Andrew!
MIRACO SCANNING DARK BRONZE SCULPTURE - untreated surface
Follow the MIRACO project on Kickstarter: Revopoint MIRACO: Standalone 3D Scanner
“Young Woman”
Author: after Demétre Chiparus (1886 – 1947)
Single Module device, near mode, single-shot mode, standard accuracy
Scanning
Fusing
Fused
3D model - Meshlab
Size - Meshmixer
Hello @dfodaro , I am new to all this, but your work really got me excited about the possibilities with miraco.
Questions - I can see when you post process on the device, but on pc, is the post processing entirely on the revopoint software?
Where do Meshlab and Meshmixer come in? Do you do some more processing on those and are they necessary to make the final 3d object look great?
Thanks!
Hi Ron,
Thanks for you appreciation!
The post-processing work is entirely done with RevoScan. In one case, the terracotta sculpture, everything was done directly on MIRACO - scanning, fusing, cleaning and editing, meshing- as you can see in the video (screen recording mode of MIRACO).
Meshmixer and Meshlab were used only for visualization, because the glossy rendering on RevoScan does not render the quality of the mesh obtained.
Thank you so much!
How many sculptures are you able to capture in a single trip on a single charge (in general)? Curious about internal memory and battery capacity on these kinds of scans. I assume you can just keep scanning and do all the post later on…? Of course it helps to do a quick check to see if your scan was sufficient I guess.
Curious if you’ve done any full body scans? I’m really curious to see full body scans with the level of detail (face mostly) that you demonstrate with your showcase.
Thank you again.
The posts MIRACO SCANNING in MUSEUM are five sculptures (and one is a sarcophagus’s more 2 meter long) scanned in the same morning, and after the battery MIRACO are not fully discharged (anyway the MIRACO battery lasts for 2 hours - I have done the test). The scans were made not by assembling separate parts but by scanning them into a single solution. The scans then were edited on pc once back to studio. If you want to see full body scans other beta testers in the MIRACO showcase section have done some.
From my experience, the internal memory is very, very generous. I tried to do tests that are similar to those showcased by @dfodaro and I never ran out of storage, far from it.
Also, a small tip: Miraco can scan objects that are behind glass, which can be useful for museums/heritage.
MIRACO SCANNING GILDED BRONZE SCULPTURE - untreated surface
**Pre order MIRACO now on Revopoint official website::**Revopoint MIRACO: Big and Small Object Standalone 3D Scanning
In an effort to showcase MIRACO’s scanning capabilities on different, untreated, dark, reflective surfaces and in suboptimal ambient light conditions, I scanned a foot of a big, gilded bronze sculpture of Hercules preserved in the Capitoline Museums.
Light condition: mixed Natural and Artificial
Type : Sculpture
Age : 2nd century B.C.
Material and technique : Gilded bronze
Size: height 241 cm
Provenance: Discovered in the 15th century in Rome, in the Foro Boario (near Campidoglio)
This is the foot (photos)
3D model - textured
3D model - MeshLab
