Hello,
There is a minor bug in RevoScan 5: there is a mismatch between the number of frames, and the frame index, which starts at 0, and whose maximum is thus equal to the number of frames minus 1.
When taking several pictures in “Single Shot” mode, the counter at the bottom right of the main window (“Rendering frames”) is correct, until the “Complete” button is pressed: rendering frame is then diminished by one.
Then, in the left hand side column, the Properties also list the number of rendering frames, but with an error of 1 frame (it takes the max index, while the correct value is the max index plus one).
Hi @Epiderme
Thank you for pointing it out .
Can you write down the software build number ( you find the whole number under “About” in the top menu bar )
I assume it the the last public build of RevoScan5 and not RevoScan5 Metrox right? What scanner you used for testing it out ?
Hello,
The software version is 5.5.3.1720
This is indeed RevoScan5, not RevoScan5 Metrox.
It is used with Mini2 scanner.
