5.4.7 dual-axis control sync with scanner
First time using the 5.4.7 version and I do not like this new feature that when the scanner pauses, the turntable stops. Is there a way to unsync them? When I turn the switch off, then neither the scanner (POP3) nor the turntable start up again.
Reason I prefer the turntable to keep rotating during a pause is so the frame # does not increase while I wait for the places that are not scanned well to rotate into scanner-view These are horse neck bones and there are some nooks and crannies that need a bit more attention.
Thanks all for any suggestions!
Pamela (Bone Lady)
Hi Pamela, that why I am using Android app for scan difficult to scan objects , the way it is now it is for simple organic objects only .
I case you don’t know already
theres should be an option for that to disable the sync
I did not used it with the RS5 software for some time …
Hi @BoneLady
Thank you very much for your feedback on V5.4.7. I will consult our R&D team on this issue. I will keep you informed if there are any updates.
May I ask why you don’t just turn off this option to keep the dual axis turntable from synchronizing with the scanner?
