Revopoint Trackit showcase - 3DVF.com
Revopoint sent us a Revopoint Trackit unit, to put it to the test.
Get yours now on Kickstarter for up to 40% off!
We published a (sponsored) article about the product over here, and here are a few scans we created, alongside our first impressions:
  • the Revopoint Trackit comes in two sturdy flight cases. The hardware is well protected and this will make it easy to store or transport the hardware if needed.
And here are a few scans:
The calibration process is mostly automated, which is nice. On-screen instructions are clear and tell you how to place the base and scanner, then the software takes care of the rest. And in the end you get a confirmation that everything went well.
My advice:
  • Use a powerful workstation: the more powerful, the better. This will increase the framerate at which 3D data is captured, make the UI more responsive, and bring down post-processing time (although to be fair, we never had to wait more than 5 to 10 minutes for a process to complete).
  • Expect a learning curve: this is a professional product, and as such, your scans will improve over time. For example, at first, we swept the scanner too fast on our subjects. Going slow and smooth, scanning one area before moving to the next is the key. The UI will also help you: when scanning, the preview is red at first, before turning yellow then green, to let you know when and where enough data has been captured.
  • Revopoint Tracking is lightweight, but your arm may get tired over time. Using the start & pause button located on the scanner, switching to the other hand or even using both hands (just make juste not to hide the markers used to track the scanner) will help you stay fresh and will keep your movements smooth.
Overall, Revopoint clearly put a lot of effort in the hardware and it shows. The scanner, base, tripod etc really feel like professional products.
I really like the two lights on the base (green = everything is ok, red = something’s up), the point cloud turning green when you’ve got enough data, and the fullscreen mode of the software. Even without a big computer screen and from a few meters away, you can still tell if everything is ok or if you need to adjust something (step back into the scanning area, keep scanning a specific area, etc).
Get Revopoint Trackit now on Kickstarter for up to 40% off!
Can you add additional Tracker Cameras like the Creafom Metrascan product for larger envelope and or better Camera Viewing on more complex scans with less Leap Frogging ? I have never used one but I was going to purchase an older one a few years back along with a Black Elite.
thank you for the review.
what specs did you have on the pc you used?
Hello, very good question, I asked the Revopoint team about this and here is their answer:
Currently, the tracker and scanner are one-to-one matches, and the multi-station is not supported for now. However, theoretically, it can be done in the future, based on further analysis of scenarios and requirements. Our product team will take this into consideration and evaluate it in the future update.
Hi Benoit, you know how it is with Revopoint, never say never ! :laughing:
Sure!
I used a HP Z2 workstation: Intel Core I7 13700, 64GB RAM, RTX 4070 Ti.
I also tried using the scanner with a less powerful workstation close to the minimum required specs, but I would advise against it. With a more powerful workstation the software is more responsive during the scan, and I feel this also has an impact on the end result.
And here is the underside of a GPU.
Scanned using marker mode (markers placed around the GPU, the base station is not used), crossed lines mode, object type set to metallic/shiny since there is solder and metallic screws.
Size: around 15cm long, small components are under 1mm.
I even managed to capture the thickness of the stickers!
Get your own Revopoint Trackit now on Kickstarter for up to 40% off!
