[Windows] Revo Scan 6 V6.0.0: What's New
Building on Revo Scan 5, the new version features a refreshed interface and an updated workflow to support future features and improve performance consistency across scanning and post-processing.
Download it here: Best 3D Scanning Software - Revo Scan 5 and Revo Software
Revo Scan 6 V1.0.0 introduces the following improvements and new features:
1)New File Management Page: Featuring file grouping to help you organize and manage your scans more efficiently.
2)Simplified File Structure: Revo Scan 6 replaces the complex project concepts of Revo Scan 5 with a simplified “one scan, one file” workflow, making file management clearer and easier to use.
3)Rebuilt Post-Processing Workflow:
① Advanced Fusion: Each file can now store up to five fusion and mesh results, preventing previous results from being overwritten and allowing multi-version data coexistence and iterative optimization.
② Simplified Post-processing Operations: A new quick-edit workflow lets you run preset actions with one click or customize parameters through a drop-down menu, significantly improving processing speed and usability.
4)Redesigned Visual Style: The main color scheme has been upgraded from black and red to black and blue, creating a more focused, modern, and professional visual experience.
5)View Layout Optimization: 3D view settings, display controls, and support tools are now placed directly in the main workspace, so key functions are easier to find and use.
Click here to explore more brand-new functions and tutorials: https://revopedia.revopoint3d.com/en/Revoscan/Revoscan6usermanual?ref=selecter&sub_id=undefined
And click here to watch the tutorial:
Hey the merging seems to be fixed :slight_smile:
I’m a little confused about the file management.
It seems that right now
  • individual files are individual scans - I don’t mean files on disk but files on the main page.
    So unlike previous version, we have to open each scan individually.
  • the new Group feature - groups contain individual files/scans - so a single group is more like a project file - so groups are closer to what we’ve seen in the previous version on the file tab?
So the process right now is:
  • launch Revoscan
  • create new group - it’s our current project
  • create new scans within our new group.
    If so, I have a request as to file management on disk.
    Right now all scans are just created as folders inside the Revoscan data folder.
    Can we please first have a group folder and the scans related to that group inside that group folder?
    So when we open the Revoscan folder we will see Group folders first, and the scan folders inside those group folders?
Hi Filip ,
Nobody wanted a project group with single scan projects inside it and it was replaced , Revo Scan 6 replaces the complex project concepts of Revo Scan 5 with a simplified “one scan, one file” workflow .
Exactly as everyone wanted.
Now you can create your own group ( base project folder ) as you please.
That’s is not exactly what I wanted personally , but hey users has spoken!
No no, it’s fine.
But I’d like this structure to be also represented by folder structure on disk.
Think of it in terms of copying your project to another computer.
It should be as easy as copying a single folder.
Right now I don’t even think it’s possible be cause you have no way of knowing which folders within the Revoscan data folder belong to your group :o
Totally agree with you Filip , that was also my point.
Moving just scans will not allow you to generate textures or after merge them on another computer. As original projects are needed with all data.
And many others things …
I will see if there is proper workflow that allows us to do it correctly .
is RS6 an upgrade of RS5 or seperated product line? and mini/range G1 not compatiable for RS6?
Is this what we asked for though?
Not that I tracked this in a spreadsheet or anything, but I saw mostly requests for:
Duplicate scans (mostly because of the destructive tools)
Split scans into groups of frames
Move scans between projects and/or merge/separate scans from/to projects
Operations between projects (ie, align scans from different projects without breaking everything with export/import)
Not… whatever this is. :slight_smile:
Hi Ken ,
Not update , just a new version supporting
Inspire series, Mini 2, Range 2, POP3, MIRACO series.
Older scanners are no more supported with this version due to its firmware and technical capacity
Please share your feedback with customer@revopoint3d.com
And the Mac version will be available soon?
Although RevoScan 5 still works with my 3d mouse, also after installing RevoScan 6, the 3d mouse does not work with RevoScan 6. I’ve also updated the 3dConnexion driver for the 3d mouse, but it does not change anything. Only zooming in/out works but with the wrong ‘gesture’. All other functions (panning, rotation, etc) do not work in RevoScan 6.
Will there be support for the 3d mouse shortly?
Hi @Zappa
Please send you feedback and question to customer@revopoint3d.com
I can confirm the same issue with spacemouse and RevoScan6. I will send a message to customer support as well.
Will it work with MetroX?
Was using MetroX software, tech told me to use Scan 5, that it would work fine.
Is this the case with this new version,?
Hi @KPUAS
The software is not to use with MetroX , MetroX use Revo Metro .
Thanks for letting me know.
Hi @KPUAS
I forgot to mention that Revo Scan 5 MetroX was used early exclusive with MetroX scanners , but it is now archived and no future updates will be available , please continue with Revo Metro from now on using your MetroX scanner.
Appreciate the update and explanation. Kind Regards
