Turntable 2.0 or my solution
Your Metrox needs marker? This is my solution:
I had the problem that the marker base stays in place when the turntable is tilted.
That’s why I designed the arms shown to hold the marker base in place with magnets. I printed M6 screws with magnets to fix them in the existing threaded bushes.
Have they helped your scanning? I have the Mini 2 and having issues with markers not working. Is this something you share?
I also use a MINI2 and had the problem that stick-on markers were not always recognised. This always occurred when the angle of the scanner hit the markers at flat angles. The 135 degree holders allowed me to use additional 3D marker blocks flexibly and thus significantly improve the scan result.
I will publish the models on Makerworld shortly.
