The latest major update is terrible metro MAC
I am having all kind of issues since I updated to the latest versino of the revo metro v5.8..5.90:
I used to run the projects directly from an external hard drive and now when I try it crases when I click complete after an scan.
The scnnaer suddenly stops scanning without finishing the complet revolution.
Every different take and position, the software struggles WAY WAY more to match the cloud point mesh.
it is slower in general.
Somebody with the same issures? I use this scanner every day for at least 4 hours in a rown. and after this lastes update it has been a nightmare to work with it. :shaking_face:
cheers
Hi @pabelim
Maybe because you use MetroX with it , there are some issues inside the system that create some bugs, and will be addressed and fixed in the mid of the March.
Uninstall the 5.8.5 including all folders before installing the older version.
install Revo Metro 5.8.4 to check if the problem disappears.
RevoMetro-5.8.4.208-windows-x86_64.exe:
Hi,
The version I am using is the Revo Metro v5.8.5.90 :frowning:
Please reinstall the older version I provided for you and wait until the mid March for the bugs being fixed for users using MetroX.
There is nothing else I can add to it.
Hi, your link is windows version, do you have the Mac version? thanks
Hi @pabelim
I don’t have info about the issue in MAC version but I will ask and let you know .
Next time please share your system info with your posts to avoid confusion .
Thank you
BTW you should never process or run your projects from any external hard drivers , the speed will suffer in both scanning and processing , the project should be saved on the fastest system hard drive and run from there for processing .
Oh, it is a thunderbolt solid state hd. It is very very stable. And it used to do very fast. But after the latest update, every time that I click r”eady” when a take is done, the software closes put of nowhere and this did not happened before. I already deleted and reinstalled the software as you told me. And it keeps doing it… in general is slower, struggles more to put the shots together, easier to loose track. It take like 20ish seconds sometimes to process one shot and keep turning.
What used to take me 1-2 mins, now takes like 10 not even kidding. Its frustrating because it use to work perfectly fine.
I already requested the link for you , once I get it I will post it.
Regarding the HD , no matter how fast it is , it will never works as fast specifically with the software.
I tried to use my thunderbolt 4 portable HD and it was much slower as well not only processing but scanning was too slow in laser mode. So usually not recommended.
Anyway the team is working on the updated so new versions will arrive mid March.
Hi @pabelim
The download link was there all the time
Please save it for the future
Download Previous Versions of Revopoint Software
Hi,
I found it and also found the older versions. I installed them from lates to back and the one that let me keep working flawlessly with my external hd and at a very good speed , compared to the new one, was the V5.6.7.287. it is from the V5.6.8.325 that everything is slow and crashing.
Thanks for the help tho :slight_smile:
Thank you for letting me know !
Glad to hear you found the better version that works for you.
Hey, when is the March Metro software update scheduled?
thanks,
Chris
I don’t know what day , but it should be already released this weekend, finger crossed :crossed_fingers:t2:
I will ask the team and let you know !
I just got info that the updates are planned not early than in 2 weeks from now on.
I just checked the download site and there has not been any update. Still showing 5.8.5
Hi @chriscraddock
April 7
That was a week ago and still no sign of it,
They had to fix some extra bugs , so they took extra time .
The updates are set to be today
Version still says 5.8.5, but date now says 04/14 :thinking:
