Hello!
I have started using my Revopoint Trackit and been very impressed by it, I think the software is great but it lacks some things and there are other features that I think should be added.
- Target Point Distance: I think when I start a scan, the target point distance should not change once I choose it, this is what I faced more than once, I choose the number say 0.3mm and start scanning, finish, start a new scan and without knowing the point distance is changed on its own to a random number or a different number that I have previously chose.
which caused me lots of issues in merging later, which after 4 or 5 scans, that took around 45 minutes maybe on complex geometry, is a huge annoyance.
I suggest that when I start a project, either I have a windows that asks me about the target point distance that I will require for this project or in the regular interface the moment I choose the number it is set and locked and will not change when I start a new scan.
Also, please do let me know if there is any benefit from changing point distance in the same project, as I have no clue if there is any benefit.
Floor Removal: either I don’t see it or it is not available, so if it is in the software please do guide me in finding it. if not it is one of the best features I’ve used in other brands, I choose 3 points or brush or select, that are on the same plane and then it will create a plane and then gives me an option to offset the plane by whatever number I put and viola scan floor is gone. if we can get this that would be great.
Texture merging: I think this is obvious, but for those who didn’t use the software still and was trying to understand the feature, when I got the trackit, I scanned an object in one position, then added texture with the texture feature then went to do it in 4 or 5 more positions.
I was then trying to merge the model which it did, but the texture is not applied for the merged model.
I don’t know if it is in the plans or not, but if this feature happens, then Revopoint Scan might just be the best accessible scanning software on the market.
anyways good job guys, I will be sharing my results soon!
