PUTV | POP 4 | Showcase 2 | 3DGS models
Revopoint3D POP 4 is currently LIVE on Kickstarter
don’t miss the chance to support this great new project > : https://revo.ink/3Rbqdid
Owl Size : 12 inches
VIDEO RS6
3D Gaussian Splat model Revo Scan 6
3D scan model Revo Scan 6
3D model OBJ Color
owl_putv_pop4
3D model OBJ
owl2_putv_pop4
Dog Size : 7 inches
VIDEO RS6
3D model OBJ Color
dog_putv_pop4
Merboy Size : 15 inches
VIDEO RS6
3D model OBJ Color
merboy_putv_pop4
3D model OBJ
merboy2_putv_pop4
Flowers Size : 13 inches
VIDEO RS6
3D model OBJ Color
flowercolr_putv_pop4
3D model OBJ
flower_putv_pop4
Lantern Size : 12 inches
VIDEO RS6
Gaussian Splatting model not only preserves shiny surfaces of the metal but also transparency of the glass object allowing actually to see inside in 3 dimension
Parkit Bird Size : 6 inches
VIDEO RS6
Blue Jay Size : 6 inches
VIDEO RS6
3D model OBJ Color
blujaycolor_putv_pop4
**3D model OBJ **
blujay_putv_pop4
MetroY Ultra Size : 12 inches
Boot Size : 11 inches
Check out my first POP 4 Showcase
SHOWCASE # 1 click here
I wanted to provide some additional details regarding the 3D Gaussian Splatting (3DGS) models and share some best practices for achieving the best results with this mode.
Please note that all the 3DGS models were created using the Hybrid + Color scanning mode. When creating these models, volume accuracy is more critical than fine scan details. To ensure a high-quality 3DGS model, I recommend placing your object against a solid-color background free of other items. Proper lighting is essential; please set your exposure and white balance to manual once you are satisfied with the camera preview at the optimal scanning distance.
During the scan, move slowly from the top down and back up to capture every angle and corner. Once the scan is complete, fuse the object using the recommended settings and clean the model thoroughly to remove any artifacts. Since 3DGS generates models based on volume, any missing data will be ignored. After fusing, mesh the model at the recommended settings, ensuring you close all possible holes and remove any loose parts.
The generation process in High Quality typically takes about 30 minutes on an RTX 4060, though this will vary depending on your hardware. Once generated, you can edit the model to remove unwanted parts and export it as either a .ply or .splat file. I recommend .ply for most web previews.
3DGS models are excellent for digital catalogs and VR because they accurately capture colors, reflections, and transparency without requiring complex material settings or specialized rendering software. Furthermore, tools like Blender can convert these into 3D OBJ models, and while Revo Scan allows for standard exports, the 3DGS conversion often provides superior results.
I hope you find these tips helpful. Please let me know if you have any questions regarding 3DGS.
Best regards,
PUTV
don’t miss the chance to support this great POP 4 new KS project > : https://revo.ink/3Rbqdid
Today a simple test scanning a bottle without any markers using Hybrid mode and color for tracking , indeed I did not lost any tracking while scanning what is a huge improvement. This means POP 4 can be used as a tool to scan and generate 3DGS models for Online Stores Catalogs and Web.
Raw data
Fused + color per vertex
Meshed + color per vertex
Textured
3DGS
3D Gaussian Splat Video
Today is the last chance to get POP 4 on Kickstarter, don’t miss your chance
Full Field mode + Color
Mesh
Mesh+ Textures
Gaussian Splatting Model
Gaussian Splatting Video
I still cant get over the quality of the 3DGS , perfect in all details
Just scanned stuff direct from the coffee table , segregated using AI in RS6
