I really like the speed and covenience of using global markers when scanning.
It is NOT recommended to use the flexible plastic marker sheets when using the MetroYPro, so I came up with another solution. I made a folding panel from two Composite Aluminium boards and covered them with reflective stickers.
I scanned the flat panels using the Global Marker Scan mode, then saved the Marker file for later use.
If I need to scan something, I just place it on the panels, then load the Marker file before scanning the point cloud.
Hi Bifi, that should work. My understanding is that the Global marker panels need to be as rigid and “Repeatable” as possible so I went with the Composite aluminium panels.
They also happen to be my old “David 3D Scanner” background corner panels that I made many years ago (You might need to google that ancient 3D scanning system, you will see how advanced current 3D scanners are
