Cant use GlobalMarker Tracking mode
New user here and I have done a few simple scans with full field and marker-tracking but I can’t use the GlobalMarker mode. All the options are grayed out. Have toggled between auto-turntable, parallel lines, cross lines etc and no go.
What am I missing here?
Cheers
Matt
Hi! Thats weird. What version so you use? Have you tried reinstalling the software?
Hi @Mattmannz
1. Prepare the Markers:
Affix markers to the object or a separate surface (like a turntable).
Ensure at least five markers are visible from each scanning angle.
Place markers randomly and avoid repeating patterns to prevent tracking confusion.
Consider using a turntable for objects that are difficult to place markers on.
2. Start Global Marker Scanning:
Create a new project in the Revo Scan software.
Select “Global Marker Tracking” as your tracking mode.
Initiate a new scan and capture the markers.
Complete the marker scan and save the global marker file.
3.Scan the Object:
If continuing, select the saved global marker file.
Choose your scanning accuracy, object type, and whether to capture color.
Begin scanning the object, ensuring the markers are visible.
Rotate the object and scan from multiple angles to capture all details.
4. Merge Scans (If Necessary):
If you captured multiple scans from different angles, merge them to create a complete model.
Tip: Once the global marker file is established, it can be used repeatedly for different objects or scans of the same object at different angles as long you did not created Global market files while the markers was on the object itself.
Here is video by our community member @Xile6 how to create and use Global Marker Mode
Thanks for the reply - running the latest version from the downloads page.
The issue is that I can’t start a scan, the buttons are greyed out. As stated the other modes work fine but the global mode doesn’t let me do anything.
Have tried all the usuals, rebooting, uninstall and reinstall etc.
Cheers
Matt
User error…. I see with Global mode that over on the top left is the new scan button…… Sorted!
