I watched a few presentations now and it seems as if outdoor tracking is only possible with the mobile app?
The mobile app clearly lists Outdoor tracking next to other tracking modes.
Revoscan 6 on PC does not - at least I haven’t been able to find this option on the scanning mode selection window.
Hi Filip , sorry but I don’t understand what you mean ? What tracking you looking for ?
The mobile app include
- Full field
- Hybrid
- VCSEL
Laser mode via Revo Mirror
Do you mean that there are no settings to use POP 4 outdoors when using with Laptop ?
I don’t think you need it , it scans so well Metals, black plastic and other as surfaces also we with Full field or Hybrid without changing any settings in PC , it is automatic without the need to adjust it , as long the Exposure is set on AUTOand the maximum distance for VCSEL at 800 mm
Hmm makes sense.
I just got confused because there is a separate button in the mobile app to indicate outdoor object scanning.
But I guess in Revoscan on PC it would be in the main window in the menu. Not in the initial setup window with scanning modes ![]()
Hi Filip,
OK some updates :
in the newest updated Beta software image A it is here in the main app, after you initiated the scanner image B
Image A:
Image B:
But it is definitely much stronger than before because I still can scan dark objects without changing the setting like here for example image C & D
image C :
image D :
