The Inspire 2 outdoor filters are probably too big.
I wish the POP 4 filters were includle in the Standard Edition.If the Premium is Battery bank grip and/or Turntable, i don’t need duplicate equipment.
Yes you are right , just checked and the Inspire 2 filters are much bigger and they are different , filtering just the infrared not the blue light that is needed for POO4 Blue laser as well.
I personally believe the accessories should be already optional, how many turntables and mini tripods you need .
POP4 also include own case in place of a box like Inspire 2.
I will ask tonight my team what is exactly different in the Standard edition, since I have only the premium edition + blue filters
Hopefully the Blue lenses will be available as ad on on KS as well.
Am I correct that no laptop or PC is required to scan (any mode) with the POP4 scanner if it is connected to an iPhone (16 Pro in my case) like my Ferrett Pro (no laptop required).
What i understand from the Revopoint live stream on Youtube :
Laser is not possible with the smartphone app.
The app for the POP 4 is not available yet (so Revo Scan 5.4.2 on Android will not works)
Hi @baylortech POP4 requires fast system to works good with the new features , beside Full Field, everything currently requires fast system and CUDA cores . The 30 laser lines will not run on smart phones . Only via Revo Mirror what is actually not exactly mirroring the PC screen , it uses the PC power
The Mobile app is still work in progress as the full project is not finished yet . The Full Field will works in mobile app and I suspect Hybrid and VCSEL as they are not dependent on CUDA cores .
