POP 4 Fused point distance
In the technical specifications of POP 4 it is stated that fused point distance is up to 0.05mm but in the latest version of revoscan(6.4.2) it is only letting me set 0.1mm when fusing any scan, how I can try 0.05mm fusing?
Hi @Olalulabog
That settings was for Full Field and Single shot mode but it was later changed to 0.10 mm , it does not affect the results much. The accuracy is already build in the sensors. The new algorithms works perfect with 0.10 mm point distance.
There is not way to use fusing distance of 0.5mm at this moment with Full Field.
But changes coming soon as well.
That’s interesting, given that full field seems to be less detailed than laser scan. I wanted to try 0.05 on laser scans because on small objects like coins or small plastic toys with knitted texture the preview before fusing looks more detailed and going by specs laser should be able to resolve that given 0.03+0.05xL volumetric accuracy on laser mode, and 0.03 single frame(but there is much more frames needed ofc than ff)
And after fusing with 0.1 it feels like there is a substantial loss of detail on such small things
Not sure what happened, may be it was a bug before but today I opened revoscan and could use 0.05 fuse on FFHD scan(first pic) but with lower accuracy of FFHD scans I think there is no point in 0.05mm fusion. Meanwhile the second one is taken in laser mode and fused in 0.1mm(as low as it will allow) and clearly there is a lot more detail, real life item has even more and I think 0.1 fuse for laser is kind of limiting it in such cases. May be there is a plan to enable 0.05mm fuse for laser it in future? And if not I hope there will be such plans :smiley:
I tried in beta t stung all fusing settings, the 0.05 mm produced not really desired results , personally Full Field with 0.03mm accuracy or 0.05mm resolution will not work good with coins.
You need at least 0.02mm accuracy for coins
The laser mode will not support 0.05 mm fusion , the algorithms will produce very noisy results , I tested it out in production , very bad results.
To get good laser scans , try to capture as much frames as possible, minimum 8K
The resolution is not what will give you here the details , the sensors and algorithms.
Trackit SR can actually scan at 0.03mm in laser mode what is a huge improvement in the game , POP4 is just an entry scanner on steroids. The power of POP4 is not the laser however is not that bad at all.
Thank you for inside info about 0.05 for laser
For the price POP 4 is awesome thats for sure, 10 years ago such device would have costed 10 times more, really happy with it
Hi @Olalulabog
No problem , I always say the same , if I only had that scanner 20 years ago … Even for a bigger price but with that ability. My life would be not the same :joy:
Regarding the 0.05mm for the laser mode , who knows what the team comes with next , higher accuracy and precision requires stability , laser scanning can’t be done from a tripod , that only already make things mode difficult because of the stabilization that is required for good accuracy and precision , markers are one of them that why Trackit SR successed with better accuracy and precision.
There is not big deal to have fusing point of 0.05mm , but what I encountered after testings at that resolution was not the quality Revopoint want to stand behind. Just to set it up can make the product looks bad in some cases as not everybody is understanding . The 0.10 mm was safe way to go in this case and pleasant fur what is offers , what don’t means things can change , the Dev. Team is working constantly in improvements with bee algorithms and we can go one day a great update that will change that.
POP 4 is one of my favorite scanner for a daily routines and goes with me everywhere. Anything better would be just a bonus, like we just got recently with color tracking scanning and laser mode. I did not expected that to happen soon to be frankly
