This is a magnetic high reflection spherical body I designed for MetroX. You can attach marker points with an outer diameter of 10mm.
The base can be fitted with a 6mm diameter magnetic rod, and the length can be chosen freely (the magnetic rod in the picture is 10mm long). If needed, you can download it from the link below.
https://makerworld.com/zh/models/929423
