Key frames editing - selection data problem
Hi !
Revoscan 5.5.4 and Miraco Pro scan.
I’m trying to remove some keyframes using the data selection tools, like lasso. I can do it (according to this : Model Editing | Revopint 3D )one time. And after deleting the selected frames, I can’t do it anymore. I have to leave the Key frames edit space, and go again… Is that a normal behavior ?
It always has been like that, and I managed to live with it, but today it’s a bit annoying for my current scan.
EDIT : I have found that each time I do this, as selecting some datas and delete the frames. I have to click on “Edit all key frames“ to be able to select data one more time. So, I found a way, but it feels awkward. And not documented anywhere.
Thanks !
Are you deleting frames or points? If you press the delete key, then you are deleting points (editing the depth maps) and you should be able to continue making selections without re-entering the Edit All Key Frames mode.
If you delete frames (with the little buttons in the list of frames) then you have to re-enter the Edit All Key Frames mode each time. I assume the reason is because it rebuilds the point cloud preview.
BTW pressing that “Edit All Key Frames” button also commits your edits (cancelling after that won’t revert the changes).
I delete frames. And now it worked. But I think there should be a more intuitive way to do this.
Sadly there hasn’t been a lot of change in how this mode works since it was introduced. Not much else to do other than learn the quirks and the workarounds. :slight_smile:
