Global site: Revopoint Pop3
US site: Revopoint Pop3
First the unboxing.
Nice simplistic box design that i always like.
Once the top is lifted you are welcome by very nicely padded box and all the standard goodies.
Pulling the scanner out
OMG we have gotten with the times and there is a standard USB type C port. YESSSSSS
Not to mention a different rear layout.
In the center we have touch buttons. +/- and Play. The +/- buttons allow you to change the exposure remotely without having to do it in app.
This is a great add on.
Coming around to the front.
We have alot more going on here then before.
There extra LEDs above each sensor. This greatly helps out each sensor.
There ones about the IR sensor help with exposure.
The ones above the RGB camera are white led for color scanning.
And it does make a different. No more mounting soft boxes to the scanner.
And these are toggle-able in software.
And it still uses Revopoint quick connect tripod setup. So all your old setups will still work just fine.
On to some scanning.
Lets try out the new color scanning. Grabbed this little guy
Very nice colors. No shadows.
And the mesh is great also
I normally don’t do color scanning. But these are great to input into a video game or website.
A few photos of lighting it in 3d Viewer
Same file just different lighting settings.
Looks great to me.
Dino Scan
Here is another color scan. It looks great.
And without textures. Look at this model. This is wonderful.
Very clean mesh model and the textures are on point.
Now on to something more like what i scan.
A turbo compressor housing.
The surface is ruff aluminum i used spray to capture the best mesh. Might have went a tad to heavy on the spray.
Also used marker mode.
The tracking stuck like glue. Very smooth and held great
Hole filled was use, because come on no scanner could get into that spacing. You can see in the photo it looks like two piece but it is one.
Did do a great job getting inside the main opening.
Great model. Can easily use this to mock up piping or check for clearance with a scan of the motor.
The Pop 3 is a great scanner well worth buying.
If you like what you see use the links below to get yours
