For better tracking when scanning corners or sharp angles, place marker points closer to the edge at a higher density than when scanning the rest of the object.
For example, POP 3’s markers should be spaced 5 cm apart in flat areas and 2 cm apart in areas near edges. The higher density of markers at the edge makes it easier for the scanner to keep track.
