Hello, I bought a new device and there was no update, what should I do to the device?
New devices have the latest firmware . In common days there will be another one .
Once you connect to WiFi you can check under Software Update for new version .
Stay tuned
The system says the software is up to date, this version is installed
Then there is no other version at this moment for your device . Check out again in next days .
Miraco Pro** Can you give me the driver? I want to install it manually. v2.5.34.20240809
Just wait 1-2 weeks, it will be released with an over the air update
You can’t install manually because there is no update available for your device at this moment .
