[Guide] How to Scan Object with Marker Mode
Introduction
Objects with geometrical features and complex shapes, scan with “Feature” mode directly;
However, when scanning objects like cups or boxes with simple geometric features, please scan with markers. Then select “Marker” mode.
Scanning Methods
There are three s canning methods :
  1. Stick markers on the surface of an object;
    Here follows a car scanning video: https://www.youtube.com/watch?v=2GPHCrbNdhE
2.Place an object on a turntable with markers;
In this method, the relative position of an object and a turntable cannot change.
To ensure that, you shall export several models of an object to merge a complete 3D model.
For example:
a. Raise the tripod to make the POP and markers being approximately 45°- 60°;
b. Adjust an “Excellent” distance;
Note: Check “√" in Clip plane.
c.Select “Marker” mode;
d.Adjust “Exposure” and “Gain” values;
e. Scanning
1st model scanning:
1)Start to scan;
2)Make sure Markers valid (more than five red dots in the center window);
3)Export 1st model;
4)Name the model Cup 1, save in ply., obj., or stl.;
2 nd model scanning:
  1. Turn the cup over;
  2. Start to scan;
3)Scan 2nd circle;
4)Export the 2nd model in ply., obj., or stl.;
f.Merge
1)Models imported in Handy Studio;
2)Mark on models;
3)Merge;
Note:
1)Scanning repeatedly couldn’t help the accuracy, and only a closer distance can improve it.
2)If necessary, you can scan more than 2 models to merge them into a complete one.
I tried marker mode on a free floating object. Unfortunately tracking is really bad. I think the software needs alot of improvements. With feature mode it was much easier to scan. However, I want to use marker mode, because of the better accuracy.
Any tipps?
Hi @mapper ,
Yes, we will keep improving the software, please don’t worry.
For the Marker Mode, please make sure that 5 or above red dots are available during your scanning process.
Cassie
Hi, I have a new Pop2 scanner. Can I use different size markers, for example, 6mm white dots with a back circle around them, too? Thanks!
From tests i have seen most markers that are available will work ok,
I think @PUTV has done some testing and is trying some new ones with the MINI, i don’t know the limits on size though, I try to use feature mode for smaller stuff ,face mode and body mode for bigger stuff with the POP2, i haven’t tried markers with the MINI yet as feature mode works really well on the MINI, i find adding features better than adding markers
Yes you can do that , 6mm for white circle will works as I was using 6mm before.
The sizes of markers works in any size with POP2 .
Size for the white dot
0.8mm
1.5mm
3mm
6mm
