Global Marker Scan Remove Markers
Is there any way to remove a marker from a global marker scan?
For my use case, I have a pre marked frame that I clamp my parts into before scanning so I can scan all around an object without needing to merge scans together. The problem is that depending on the part geometry I sometimes loose marker tracking when scanning the center of the object.
I would like the ability to have my global marker scan saved, and if necessary, add additional markers to the object and use the continue scanning function to add the new markers the global marker cloud l. Once the scan is complete I would remove the added markers from the global cloud
You can’t add Global Markers or remove them , that’s not how the function is working in the software . Once the global markers are captured , they can’t be altered or change it’s original location.
So sorry but I can’t help you here with .
