imo, both ios/ android revoscan application is convenience for scanning, but not editing and meshing, all details gone for mobile meshing, wondering if the functions are the same , compared with android/ios application and miraco software?
The RAM (Random Access Memory) varies. Mobile devices typically have 2GB of RAM, while MIRACO has a minimum of 16GB and a maximum of 32GB. This means that MIRACO can handle more intricate processing without experiencing crashes.
The texture effects differ. MIRACO supports 8K Color Capture, resulting in significantly higher clarity.
I only scan using mobile and the functionality is the same , my new phone support 24GB Ram so it is more than MIRACO 16GB , however mobile Revo Scan processing is lower so not the same quality as on MIRACO …
However for just scanning the mobile device is just fine , later I just process it on my PC for best quality .
You can’t run Revo Scan on a mobile phone with 2GB RAM , you need at least 6GB RAM from what at least 4GB Ram is available for the software . With 12GB of Ram on your phone you will have 7GB RAM to disposition what is plenty , you can scan half room with it and still not reach the maximum frames.
Miraco 16GB have to disposition around 12GB RAM for scanning , the rest is needed for the operating system
