thought I would show everyone what I’ve just scanned last night
I did in multiple sections mainly because the body is fiberglass and the owner didn’t want anything stuck to the aircraft
I’ll get some dimensions soon
It took about 2 hours to do the whole thing, the surface aria of the wing is quite large and had to lay on the floor to get the underside but with the hight set on the tracker correctly both sides of the wing could be done in one setup, each wing was a little over what the Trackit could do in one position lengthwise so probably 5 meters long and around 1 meter wide at the widest point
this is the fused results without any major cleanup yet
when I’ve cleaned up and meshed this I’ll post some more pictures
