Hi everyone. Revo Scan 5.6.7 MetroX for Windows and macOS are now available on the official website.
Download it at:
Updates:
Optimizes the user experience for scanning large objects.
Download it at:
Updates:
Hi,
I can’t seem to run this on Mac. Apple silicon not supported? Thanks
Hi @phantom1
The macOS versions of Revopoint’s software, such as Revo Scan 5 , are primarily designed for Intel Macs and run in emulation mode under Rosetta 2 on Apple silicon Macs. This means the software is translated to run on the different architecture.
If you experience any issues please contact customer@revopoint3d.com
for technical assistance.
4 posts were split to a new topic: Issues with Merge RSMetroX
Hello!
In version V5.6.7 and in the previous version V5.6.6, “Fusion” function seems to be deleting a lot more captured points than in the older versions and therefore “Merge” is much more difficult (both in Feature and Manual Alignment)… Is there a remedy? (I already tried Fusion in all different point distances!)
Or, where can I find the earlier versions of the software to download?
Thanks in advance!
Hi @Fofo
There are no early versions to download . I recommend you keep early version before you install new one , you can rename the RevoScanMetroX soft folder under Program Files before installing a new version or keep an download copy .
Never use old software to calibrate your devices.
Thanks for submitting your issues regarding removed parts after fusing , I will forward it again to the team .
Thanks for the answer!
Maybe customer support could provide me with the earlier version? Where should I address my request?
Hi @Fofo
You can email to customer@revopoint3d.com and request it there, not guaranteed but “ NO “ you have already ![]()
Hi!
Which version do you need? I might have it in my archive.
Ivan, thanks so much for your kind offer to help! You’re awesome! ![]()
Any version prior to 5.6.5 would do. Maybe the earlier the better!
It’s almost 10:30 pm here and unfortunately I am already in my bed. I am sure I have older version I can share with you, and I will do that tomorrow morning. ![]()
Thank you! Have a good rest!
I sent you the download link to your mail-address. ![]()
Hallo Ivan,ich hoffe, dass es Dir gut geht.
Ivan!!! You’ve saved me!!! Version 5.6.4 works like a charm!!
Big hug for your generous help!
Infinite thanks
Message to the developers: FIX THIS ISSUE ASAP
Great! Very glad it helped! Happy scanning! ![]()
Tried to use the newest version and my workstataion and it just full throttles the cpu when starting the software and control of the software is very slow. I did have the previous verison 5.6.6 and it ran “better”, but would crash randomly. I thankfully have the 5.6.4 version on my laptop and it runs fine. Is there something that I need to do different?
For some reason on different Systems things works differently. I can’t say I relate with your issues neither in my laptop or my workstation .
However there is a new version in making so I hope it will works better on your system .
There is nothing else you can do at this moment that wait a little bit for the new updates.
Glad to know there is another version coming. They seem to be doing a good job of getting updates out.
