A few days ago I received these two large boxes from revopoint, slightly bumped and bashed but not too bad
Happily the contents was these two very robust hard cases which only had some light scratches on the surface,
Bothe have built in wheels and handles
The smaller one has an extending handle to make it easy to move around
Inside the boxes
2 sided Carbon fiber calibration board, all cables and some accessories are safely kept in the top of the smaller case
more Carbon fiber with the calibration pole, Tracker is an impressive bit of kit, 3 very robust tripods are included, 2 in the tracker case and one in the scanner case
the carbon fiber is even more impressive on the scanner! In the bottom of the smaller case we have 2 calibration gimbles, calibration board tripod and 6 tracking balls that are neatly fitted into the foam
the 6 tracking balls and some magnetic markers are for multi position scanning where the tracker is used to scan the markers for global tracking on larger jobs
I will give you more info in some showcases very soon ![]()
