Hi Guys, can anyome help me with a program or software to compare the images? I work with facials and do heaps od before and after pictures. I use Pop 1 to scan my clients and I’m looking for a software to do this before and afters.
Thank you!!
Thank you!!
Hi! Do you want to compare 2d or 3d Images?
I would like to compare 3D images
You might look into mighty freeware cloudcompare for all sort of useful functions.
https://www.cloudcompare.org/doc/wiki/index.php/How_to_compare_two_3D_entities
Thank you very very much! I’ll check that out!
Hello Isabela , you can see the models images next to each other using Revo Studio, load first the older 3D model , then load the new model under Align , then you have 2 models next to each other at the same time , I think that is what you wanted ? to have 2 face models at once next to each other?
I don’t think Cloud Compare is what you needed since you are not doing facial surgery
and there will be not significial changes in the face value.
But you can also load 2 models into Cloud Compare and see it at once in one window.
Thank you for your reply! This is exactly what I need. I’ll try for sure. Just one question, can I save the models next to each other or we use the Revo Studio just to see the comparison? Thank you very much!!!
In this case you will have only next to each other for comparison .
If you want save them together , I recommend to download free Cloud Compare , load both models, orient each to your liking , select both of them and export( save) together . Later you can quick view them in Revo Studio or Windows 3D preview
