I am currently using Revo Metro 5.8.5 on Windows 11 and cannot seem to get it to drag onto another monitor from the main one without several tries and closing and reopening. As soon as I try, the UI jumps back to the main monitor and does some weird resizing. Also, the window resize options for the window chrome are only at the bottom right. If I drag it quickly to one screen and manage to get it to fit that monitor, as soon as I try to drag it again, it goes back to the main monitor. It also doesn’t remember which screen it was last set to after closing the app. If I am at the project load screen and move it to another screen and then load a project, the app moves it back to main screen again. This is extremely annoying! This is basic UI/UX design. If you override window chrome, you need to do it correctly or you get weird behavior like this. Please fix!!
Scratch that, this app does not work even if you manage to get it to another screen. None of the controls work and has to be manually shut down. Note, I am using a laptop and two additional monitors. This should not be a problem but whatever framework this app uses for the base UI setup is a poor design.
Hi @ModMan please share your feedback direct with the technician at
customer@revopoint3d.com you can add the link to this thread for a reference.
Thanks for your feedback!
I am having the same problem
