Range 2 Depth Accuracy at Maximum Scanning Distance?
I’ve been reviewing the specs for the Revopoint scanners and I do not see this addressed, but I am asking specifically for the Range 2.
At the Range 2’s maximum spec’d scanning distance (1.3 m), what is the accuracy of the depth measurement? As an example, a sculpture with a section of flat surface raised above another flat surface. As another example, a flat surface with a hole large enough to be scanned.
Scanner accuracy are measured by it closer distance in Excellent mode and according to it’s hardware capacity and not by the far distance, you can scan and object and measure what is the point distance in the point cloud to find out specifically for your scan at far distance.
Using CC will do the measurements for you.
