[Miraco] Feature Request: Add delete function for Mesh and Fused Point Cloud
Hi,
I’d like to be able to delete a mesh (and fused data) directly on the Miraco in order to save on storage space. I sometimes generate the mesh on the device to verify that a scan was successful, but I don’t need to keep the mesh on the device. As it is read-only during file transfer, I also can’t simply delete the mesh files manually (and edit the meta-files)
So in pactice I have several gigabytes of meshes on the device that I don’t actually need there.
Thank you for considering this
Best regards
Johannes
Hi Johannes ,
You should not keep projects on MIRACO , download it and backup your copy then clean it .
I lost all my projects when I needed to restore my system , not really safe plus one day if you have to download it all , it will take hours , since it get full sooner or later with meshes or without .
The request to remove the mesh is very good , because it will also speed up the download of the project . I don’t think it would be hard to add that feature .
