Miraco + Dual Axis Turntable + Automatic SIngle Shoot
Is there any possibility using MIRACO + Dual Axis Turntable to do automatic single shoot like Metro Y did.
minute 1:42:40
I just found out that Revo Scan 6 just launch, but there’s no option like it. So RevoScan 5 still my best choice. If there’s no future update about MIRACO, so maybe I just need to buy a new Metro Y.
You can do it, but its not automatic. You just use the turn table and do single shot. You have to click to take the shot. But the Miraco can do color scans in any mode, where the metroY does not do color in laser scanning (for obvious reasons).
What is your intended use case?
Hi @danpandapotan
Miraco single shot is simply a Full Field single frame shot, MetroY Pro single shot is completely different mode than Full Field as it uses 2-3 frames adjusting in different pattern before adding it to the scan, so not the same as the manual single shot .
So the answer is sadly NO , you can’t recreate the Auto mode. But you can move the object of the turntable in steps and manually capture single frames , they may be not as precise as MetroX’s or MetroY Pro, but better than Full Field in continuing scanning .
Note: Only MetroY Pro have an Auto color mode , MetroY don’t have Full Field or Auto mode it is just a laser scanner.
