Large-scale scanning just lost its wires
With the Trackit SR, multi-station scanning is no longer a cable puzzle.
Reposition the Tracker as needed to capture every angle of a bulky workpiece. The system performs real-time tracking, merging each station’s data into a single, comprehensive model as you work. You get the entire scan in one go, eliminating the need for manual alignment in post-processing.
This fluid workflow is built on a foundation of industrial precision. With a volumetric accuracy of 0.025 mm + 0.04 mm × L (m), every station transition remains tight and reliable.
Experience the efficiency of a wire-free, unified scanning process.
Use code [MEDIAFO12] at checkout for an exclusive discount!
US Store | Global Store
