5 Things You’ll Never Do Again After Getting Revopoint Trackit
If you’ve used traditional 3D scanners, you understand the struggle. Markers, shaky scans, endless setup. But with Revopoint Trackit ’s marker-free optical tracking system, those frustrations are a thing of the past. Here are five things you’ll never spend time on again.
1. Stick Markers All Over Your Object
Say goodbye to the ritual of dotting your part with dozens or hundreds of markers . With Trackit, all tracking occurs from a base station that monitors the scanner, not the object. You get accurate, aligned scans without touching the object once.
2. Peel Them Off. One. By. One.
Marker removal is tedious, especially when scanning painted, delicate, or oily surfaces. Skip it entirely. When the scan ’ s done, you ’ re done.
3. Worry About Losing Tracking Mid-Scan
Traditional scanners lose tracking easily if the object lacks texture or features. Trackit’s dual-camera base station locks onto the scanner’s position, even if you’re moving fast, scanning in low light, or working with featureless surfaces. No more rescans. No more time lost.
4. Spend Ages Calibrating
Other tracking systems have long, multi-step manual calibration processes that can take up to an hour to complete. Trackit’s dual-axis gimbal system powers an automated calibration process that completes in around 25 minutes , which is over 50% faster than other systems.
5. Dread Scanning Big Stuff
In the past, scanning large objects meant hours of prep and constant repositioning. Trackit makes it simple. Just “ leapfrog” the base station around the workpiece, place some anchor points, and keep scanning. No markers. No clean up . No stress.
Bonus: You ’ ll Want to Scan More Often
When the tech stops getting in your way, scanning becomes a tool, not a chore. Trackit lets you capture precise, professional-grade 3D models faster than ever. More scans. More projects. More done.
Ditch markers and double your scanning efficiency with Trackit. Now on Kickstarter for up to 50% off.
