Greetings
In the video you can see how i’m using a 4th model to align 3 partial models and how each model keeps the new position.
It however messes up when i disable the 4th lower rez alignment model and try to make the merge.
This is probably a easy thing to fix and add this as a new feature
Hello X3msnake,
Thank you for bringing this to our attention.
Please try merging the models one by one, and since this is a symmetrical object, please try manual alignment instead. You can read a merging article here: https://support.revopoint3d.com/hc/en-us/articles/24035893715995-How-do-I-merge-models.
I hope it works for you.
If it doesn’t, please contact our customer service at customer@revopoint3d.com. We would love to help you resolve this.
Kind Regards,
Leann
Revopoint CS Team
I would like to see two separate functions - “alignment” and “merging”. So that after aligning I could go back to individual scans, correct something if necessary, and only then do the assembly.
I think what is being asked for is the ability to lock a scan’s position after the “Preview the Alignment” step. Right now it seems that Generate Model tries realigning everything which often results in a misaligned model if you go back and edit a scan, or in this case uncheck a scan that was strictly meant to be used to align the others.
Correct. that is the issue. i stumbled upon this potencial feature, like pre-lignint to a low rez model but it screws up the alteady aligned models as one can see on the video that the coordinates are already stored between operations on the preview
this is a simple implementation
I know how the software works this post is not a newbie looking for help this is a feature request that is easy to implement Masters
Hello Users!
Thank you for clarifying that for me.
I will inform our developers regarding this, and we will review the possibility for the next update.
We appreciate you bringing this to our attention and helping produce a user-friendly experience in optimizing the features.
Your efforts are highly appreciated!
Warm Regards,
Leann
Revopoint CS Team
