Link to the video: https://youtu.be/LgZ9zk6j0RA
Following the initial accuracy tests of the competitor Sermoon S1, competitor's scanner Rockit and Revopoint MetroY Pro and other scanners up to date it is now time for the Revopoint Trackit.
Coming tests will feature the Einscan Rigil and Sermoon P1 as well as some scan modes I missed on the already tested scanners since I only started with laser mode. Video shows the whole process and for those asking: the Micrometer was is calibrated before each test.
Disclaimer: I will redo the Rockit scan since I only captured 5 samples and it was the first test (cannot say with certainty I didn’t rotate the turntable while scanning). Sadly cannot do the same with the Sermoon S1 since I sold it a time ago.
TLDR of the results (for marker tracking)
- Nominal: 124,984mm +/- 0.01mm
- Mean: 124,980 (6 measurements)
- ∆mean: 0,004
- StDev: 0,01
TLDR of the results (for tracker tracking, feshly calibrated)
- Spec: 0,025mm for Nominal
- Mean: 125,025
- ∆mean: 0,04
- StDev: 0,02
Remember: Calibrate your Trackit regularly for best results, no other way around it.
